Analyzers
5342 Discussions
Profiling Fortran code with VTune on Linux
Dny
Hello ,
I'm profiling a code in fortran 90 using VTune Performance Analyzer 9.1 for Linux* build 226 .
I have a file which has a subroutine (E.g. INNER_SUBROUTINE) defined inside another subroutine(E.g. OUTER_SUBROUTINE) and outer subroutine call to inner subroutine.
But when I goes down to function level in VTune it shows me different function name .
When I go down to see the source code vtune giving an error "Cannot open Source view data".
See the sample code below.
SUBROUTINE OUTER_SUBROUTINE(NM)
CALL INNER_SUBROUTINE (NM)
CONTAINS
SUBROUTINE INNER_SUBROUTINE (NM)
END SUBROUTINE INNER_SUBROUTINE
END SUBROUTINE OUTER_SUBROUTINE
Can you please tell me how I can drill down to source of hotspot function for fortran subroutine?
In VTune I see the function name which is formed by module name , outer subsroutine name and inner subroutine name (I observe that it has format __ ). It means we cant find same function name in any of my source files , so VTune giving me error of not able to view data .
Can you please guide me how should I compile (any specific flags to be used ) my application so that I can see the source code of hot spot function in VTune.
Thanking You,
Dny
Huseyin_A_Intel1
Hi Dny,
VTune Performance Analyzer 9.1 supports analyzing and viewing the source code of Fortran applications/code.
Could you please let me know which compiler and compiler options you are currently using? Are you using -g in order to produce debug information?
Also if you are using high-level optimizations (e.g: -O2, -O3), does this problem still happen under VTune Analyzer when all optimizations are turned off (e.g: -O0 - inlining could be a problem)?
Few things to try out maybe
- How does nm show the symbol information?
- Does gdb (or idb) work on this binary as expected? Can you set breakpoints on the inner and outer subroutines and step appropriately?
Levent
Huseyin_A_Intel1
Hi again,
I will also recommend you to check out the "About Symbol and Line Number Information" section in the VTune Analyzer help file for more information.
Levent
Dny
Quoting - Levent (Intel)
Hi Dny,
Levent
Hello Sir,
Thanks for your reply.
I'm using icc 11.0.074 for Linux following compiler flags for building my application.
-g -O2 -xSSSE3 -ip -no-prec-div -opt-prefetch -parallel -static
I also observe that nm shows the same symbol information (function name) as VTune shows.
Thanking you,
Digambar
TimP
Quoting - Dny
As the previous reply said, it might be interesting to know whether you can step through the internal subroutine (if that is still the problem you are discussing) in a debugger, as another check on whether the debug symbol connections are satisfactory. Also, replacing -ip with -fno-inline-functions, and removing -parallel, might be interesting tests.
It still looks like you may have to submit a problem report with a reproducer, as chatting without specifics has its limitations.
