Analyzers
5338 Discussions
Profiling workloads within toil
kaplannp
I'd like to use vtune hotspots to profile an application from the command line. The application uses toil internally , and I'd like to get profiling results for all the jobs within the toil pipeline. Is this possible using vtune? When I try the obvious `vtune -collect hotspots ./myapp` the application hangs.
Any leads or pointers to documentation would be greatly appreciated!
Noah
yuzhang3_intel
Try using hardware event-based sampling mode instead.
vtune -collect hotspots -knob sampling-mode=hw ./myapp
yuzhang3_intel
kaplannp
Thanks for the help!
This works for some inputs to my application, but on other inputs it freezes and produces
"kernel:[ 1948.765550] watchdog: BUG: soft lockup - CPU#30 stuck for 52s! [_toil_worker:8611]"
-----------EDIT---------------
I've fixed the issue. It was related to the -knob enable-stack-collection=true flag that I was passing to vtune, which caused the machine to run out of memory.
Accepting the answer as this solved my first question.
yuzhang3_intel
You can specify the the option '-data-limit' to limit the amount of raw data (in MB) collection.
vtune -collect hotspots -data-limit=200 myApp
For details, please refer to the User Guide below:
https://www.intel.com/content/www/us/en/docs/vtune-profiler/user-guide/2024-2/data-limit.html
