I used Inspector XE to run analysis on a matrix multiplication algorithm, where matrix C = A x B.
Matrices A, B, and C are initialized using dynamic memory allocation. Race condition problem was detected at line 80.
80 #pragma omp parallel shared (A, B, TEMP) private(i, j)
81 {
82
83 #pragma omp for
84 for (i=0 ; i<N ; i++)
85 {
86 for (j=0 ; j<N ; j++)
87 {
88 A = i + 1;
89 B = i + j;
90 }
91 }
92 }
However, the final result (printf result), which is the content of matrix C is correct.
I thought that race condition would cause the final result wrong, but the opposite happened. Why?
Thank you.
I tried to reproduce this problem with your piece of example code (please see my attachment, matrix_multiply.c), but the problem was not found.
Could it be due to different compiler version or inspector version?
# icc -g -openmp matrix_multiply.c -qopt-report -qopt-report-file=stdout -o matrix_multiply -lpthread
Intel(R) Advisor can now assist with vectorization and show optimization
report messages with your source code.
See "https://software.intel.com/en-us/intel-advisor-xe" for details.
Report from: OpenMP optimizations [openmp]
matrix_multiply.c(12:1-12:1):OMP:Initalzie: OpenMP DEFINED REGION WAS PARALLELIZED
matrix_multiply.c(33:1-33:1):OMP:multiply: OpenMP DEFINED REGION WAS PARALLELIZED
# ./matrix_multiply
# inspxe-cl -c ti3 -- ./matrix_multiply
0 new problem(s) found
# icc -V
Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.0.109 Build 20150815
Copyright (C) 1985-2015 Intel Corporation. All rights reserved.
# inspxe-cl -version
Intel(R) Inspector XE 2016 (build 423441) Command Line tool
Copyright (C) 2009-2015 Intel Corporation. All rights reserved.
# ./matrix_multiply
# icc -V
