Analyzers
Community support for Analyzers (Intel VTune™ Profiler, Intel Advisor, Intel Inspector)
4824 Discussions
SB_DRAIN.ANY and RESOURCE_STALLS.STORE
Tushar_S_
hi all
I have difficulty in understanding westmere pmc counters SB_DRAIN.ANY and RESOURCE_STALLS.STORE
Could you please let me know what exactly these counters do?
thanks
-ts
TimP
Black Belt
The posted definitions seem clearer than many.
On the assumption that the store buffer events relate to the fill buffers, did you consult
https://software.intel.com/sites/products/collateral/hpc/vtune/performance_analysis_guide.pdf ?
Do you also see significant counts on one of those fill buffer events?
A typical situation might be that the code is updating more than 10 cache lines in a loop, so that partially updated cache lines have to be flushed and replaced with contents of the next cache line to be updated.
As the resource stall definition specifically calls out 5 possibilities (each of which has its own specific counter, including a store buffer event), I doubt anyone could tell at a distance which of those it might be.  They seem to have in common that they are pipeline stalls or stalls on instructions which specifically require waiting for the pipeline to clear.
TimP
Black Belt
