Analyzers
5307 Discussions
SEP hangs Red Hat 5.3 with Xen
Dean_C_Intel
Trying to install product launching SEP driver hangs my system.
kernel is Linux 2.6.18-128.el5xen running in DOM0
Mark_D_Intel
Hardware sampling is not supported inside VM's (and the DOM0 instance is still a VM). If the base system must use Xen kernel, you might have better luck running inside a fully (hardware) virtualized guest OS (though I'm not sure if the version of Xen in RH5.3 supports the necessary PMU virtualization or not).
Mark
