Analyzers
SIGSEGV on amplxe-runss
tupinamba__andre
We have a Linux box that I need to profile remotely. But it is failing to run `amplxe-runss -V` with a SIGSEGV (null pointer).
/var/mnt/disk0/misc/vtune_amplifier_2019.4.0.597835/bin64 # ./amplxe-runss -V
log4cplus:ERROR No appenders could be found for logger (perfrun.perfcollector).
log4cplus:ERROR Please initialize the log4cplus system properly.
amplxe: Fatal error: Unknown critical error
Aborted
Running under strace, the last lines before the SIGSEGV:
stat("/var/mnt/disk0/misc/vtune_amplifier_2019.4.0.597835/bin64/sep", {st_mode=S_IFREG|0755, st_size=381800, ...}) = 0
uname({sysname="Linux", nodename="probe654", ...}) = 0
mmap(NULL, 528384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fc9e7bd9000
write(2, "amplxe: Fatal error: Unknown cri"..., 44amplxe: Fatal error: Unknown critical error
) = 44
--- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=NULL} ---
Please find the crash info attached
The environment is a Linux from scratch
/var/mnt/disk0/misc/vtune_amplifier_2019.4.0.597835/bin64 # uname -a
Linux probe654 4.14.33 #1 SMP PREEMPT Wed Jul 24 05:49:14 IST 2019 x86_64 GNU/Linux
model name      : Intel(R) Xeon(R) CPU E5-2620 v2 @ 2.10GHz
Any idea what can I do?
Many thanks
André Tupinambá
Andrey_I_Intel
Hi Andre,
We have seen a similar issue on very old systems like RHEL 6.3, which is not supported by VTune anymore. This looks like runtimes incompatibility but it was not looked into further. Try VTune 2019 Update 1, it was the last version that had support for RHEL 6.7 and lower.
BR,
Andrey
Andrey_I_Intel
Hi Andre,
BR,
Andrey
tupinamba__andre
Hi Andrey,
I'll try to install this old version.
However, I tried to run the amplxe-runss on a chroot environment, simulating our hardware, on my machine (Ubuntu 18.04) and it failed as well. My guess relies on something missing in the filesystem. I have complete control of this Linux environment, if you have any guess of what it could be missing, please let me know.
Thank you
Best
André
tupinamba__andre
Andrey,
The 2019 update 1 worked.
Thank you again.
Best
André
Andrey_I_Intel
Andre, could you please post your libc version? It can be checked by launching libc.so, for example like this on Ubuntu:
$ /lib/x86_64-linux-gnu/libc.so.6
GNU C Library (Ubuntu GLIBC 2.23-0ubuntu10) stable release version 2.23, by Roland McGrath et al.
Copyright (C) 2016 Free Software Foundation, Inc.
tupinamba__andre
CNX-atupinamba:~$ /lib/libc.so.6
GNU C Library (EGLIBC) stable release version 2.13, by Roland McGrath et al.
Copyright (C) 2011 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
Compiled by GNU CC version 4.9.3.
Compiled on a Linux 4.1.15 system on 2018-10-17.
Available extensions:
        crypt add-on version 2.1 by Michael Glad and others
        GNU Libidn by Simon Josefsson
        Native POSIX Threads Library by Ulrich Drepper et al
        BIND-8.2.3-T5B
libc ABIs: UNIQUE IFUNC
For bug reporting instructions, please see:
<http://www.eglibc.org/issues/>.
Andrey_I_Intel
My initial assumption was that the issue was observed on systems with fairly old glibc, and your eglibc version is dated 2011. Updating it to a more recent glibc release would probably fix it with the recent VTune releases, although I have doubts since you have already tried chroot.
tupinamba__andre
The chroot environment uses this old libc as well. I'll update it to check.
tupinamba__andre
A small update on this.
We (finally) update the glibc on our environment, now with 2.25.
Now I was able to run the VTune 2019 update 8 without problems.
Thank you again.
Cheers
