Analyzers
5285 Discussions
Scripting for running automated Vtune experiments.
sharshera
I have 40 test cases that I want to push through Vtune and I want to get their callgraphs on the same peice of code.
I currently do that manually with vtlec.
I have used vtl before but I wonder is there a way where I can save the output result of vtl and then just view it with vtlec later on.
Thank you guys very much.
Hameed.
jeffrey-gallagher
After you've collected data using vtl:
1) pack the data, creating a .vxp file
$ vtl pack filename.vxp
2) Then import that .vxp file using vtlec:
File --> import
Works like a champ!
IF however, all you want is a gui to view your sampling and callgraph data from vtl, try the plug in viewers:
$ vtl view # show me the ASCII data from my last activity
or
$ vtl view -gui # show me the same data, but with a viewer
See what you think.
cheers
jdg
sharshera
How to differentiate between different .vxp files?
I have 20 or more experiments, how to know which one is which, there is lots of vxp files under my workspace?
Thanks very much.
jeffrey-gallagher
The pack option packs up the entire project. You pick the file name at least the part before the .vxp.
To experiment, I'd suggest running vtl in a new directory, create a single profiling experiment, and then pack that up, import it to the GUI, see if this is going to be what you need or not.
For more:
$ man vtl
(look for pack option)
cheers,
jdg
