Analyzers
5327 Discussions
Serious error in source view of Java
edwh
I'm doing call sampling on a Java app. When I try to go into the source view for one function, I see:
A serious error occurred in file e:\vttbuild\workspaces\vtune_linux_0\source\sourceviewwin-1.0.9-27192\units\svdp\src\VTSvdp.cpp at line 1557 (Unexpected problem has occurred. The Source Window will now be closed.). The failed HRESULT that produced this error is 0x80340001. Please contact technical support.
Peter_W_Intel
First at all, what VTune Performance Analyzer are you using? latest product is v9.1. Secondary please check supported JVMs in release notes.
Also you have to use "-g" option to build your .java files to generate debug info in your class files.
If the problem persists on, you may go to https://premier.intel.com to submit your issue with test case.
Regads, Peter
