Analyzers
5281 Discussions
Setting sampling rate via command line when using amplxe-cl?
Jason_Spangler
Hi Intel,
How do we set the sampling rate during hotspot sampling to something higher when running our server processes via the command line amplxe-cl program? We cant find a command line option to do so.
Thanks!
Vladimir_T_Intel
We do not allow changing the sample rate for the Hotspot analysis collection. The reason is that we have chosen a sample rate which is a good compromise between overhead/disturbance and the statistical correctness of data. In case you need a higher resolution, use the lightweight-hotspots playing with the Sample After value (SAV) for the CPU clockticks event. But be careful - too frequent sampling may hang the system.
Vladimir_T_Intel
Also, take a look at this thread
