Analyzers
5250 Discussions
Slow Level 2 analysis
manik_s_
I have a graphics application and I want to run level 2 memory analysis on it.
But the application, because of the intel inspector, has become very very slow in response , so much so that it is impossible to play the game.
I have excluded all the modules that I do not want to instrument for analyses, but still the system is too slow(unplayable).
Can you suggest what more I can do to achieve more speed in terms of responsiveness of the game ?
Peter_W_Intel
You might create a new analysis type, copied from mi2 analysis. Thus, you can set stack-depth=1, unselect "Analzye stack access", select "Remove duplicates", etc. Have you tried such as "-module-filter-mode=include -module-filter=.\foo.exe" instead of "-module-filter-mode=exclude ..."?
manik_s_
putting a sleep in the main renderer thread improved the performance a bit.
Peter_W_Intel
Probably CPU utilization will be reduced when Inspector instruments/executes on "sleep" function. My opinion is to remain some core unused (application cpu affinity?), so Inspector will use other spare cores.
also, Inspector XE Update 9 enhances on the performance. Have you tried that?
manik_s_
I am already using update 9 of Intel Inspector XE
Bernard
Valued Contributor I
Probably CPU spends too much time executing instrumentation code and/or too much time is spent executing higher priority thread/code.You can try to profile your app when it executes under Inspector.You can use Xperf tool for that.
