Analyzers
5250 Discussions
Step by step guide for tachyon example Inspector XE
Sangamesh_B_
I'm a beginner to Intel Inspector XE. I used the given sample program tachyon to start with. There is no readme file inside the tachyon folder to know the steps to follow. The advisorXE has a readme document which will guide how to use the example, and is more useful. Can you provide a similar document for InspectorXE & tachyon
Holly_W_Intel
I don't know whether you are working on Linux or Windows, but if you go to https://software.intel.com/en-us/intel-inspector-xe and click on the "learn" tab and then the "documentation and tutorials" tab you can find a complete tutorial for doing both memory and threading analysis that uses the tachyon code as the example.
Hope this helps
