Analyzers
5268 Discussions
Summary report missing CPU time information
bruceh
We are seeing intermittent missing CPU time information from the summary report.  What can cause this?
Compare these two reports for the same app on different machines (I removed the computer name from the report) and
CPU Time
Effective Time
Spin Time
Overhead Time
Total Thread Count
Paused Time
are missing from the one.
JaideepK_Intel
Can you please answer the following questions:
  • Processor details of both the machines.
  • Sample reproducer and steps to reproduce it.
  • To confirm, the analysis type on each machine. Have you selected additional options while profiling your application?
  • Please attach self-checker logs by running the below command.
<Vtune_installation_directory\latest\bin64\vtune-self-checker.bat> for windows.
<Vtune_installation_directory\latest\bin64\vtune-self-checker.sh> for linux.
Jaideep
JaideepK_Intel
Could you please share the details mentioned above? so we can reproduce your issue from our end.
Jaideep
bruceh
I'm afraid I cannot give you a working sample because that would require our product be included.
Analysis type is just vtune -c hotspots for both
We have not run any other options.
Both machines are the same:
Processor:  Intel(R) Xeon(R) E-2144G CPU @ 3.60GHz 3.60 GHz
Installed RAM: 16.0 GB
System type: 64-bit operating system, x64-based processor
Production machine is
Windows 10 Pro for Workstations
Personal machine is
Windows 10 Enterprise
Since this is intermittent on the production machine, I cannot be certain it would never happen on my personal development machine.  It hasn't yet.
vtune-self-checker log files are attached.
JaideepK_Intel
Thank you for sharing the self-check logs. I assume you are not running the Vtune application as an administrator (missing data system). Please try to run the same analysis on Vtune as an administrator.
If the problem persists, please follow the steps below:
Launch the command prompt as an administrator and set Vtune environment variables with the below command.
<vtune_installtion_directory>\Intel\oneAPI\vtune\latest\vtune-vars.bat
The default installation directory is (C:\Program Files (x86)\Intel\oneAPI\vtune\latest\vtune-vars.bat)
1. Check dependencies with the below command:
C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64\amplxe-sepreg.exe -c
2. Check the driver's status with the below command:
C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64\amplxe-sepreg.exe -s
3. If any drivers are not installed properly, use the below command to install them:
C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64\amplxe-sepreg.exe -i
If the issue still persists, please let us know.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issues.
Jaideep
JaideepK_Intel
Jaideep
JaideepK_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
