Analyzers
Community support for Analyzers (Intel VTune™ Profiler, Intel Advisor, Intel Inspector)
4925 Discussions
Tbs.sys and BSOD on Windows XP
slavai
Hello!
Driver tbs.sys( Product 6.0 File Version 5.1.0.0 ), Intel VTune 7.1 for Windows XP, hase the following bug:
It calls ExCreateCallback at IRQL>DISPATCH_LEVEL, this is result in BSOD with error IRQL_NOT_LESS_OR_EQUAL, this is call stack
f42d7930 805c520d badb0d00 f42d79d4 f42d798c nt!KiTrap0E+0x233
f42d79a0 f6b1cdb6 f6b27338 f42d79b8 00000000 nt!ExCreateCallback
WARNING: Stack unwind information not available. Following frames may be wrong.
f42d79dc f6b1d87d 820d5ca8 0000000f 00000000 Tbs+0x3db6
f42d7a14 f6b1da77 000008d0 00000000 8067379c Tbs+0x487d
f42d7a28 804e3d77 820d5ca8 83750f68 806ee2e8 Tbs+0x4a77
f42d7a38 8066a2c5 83750f78 83750f68 81c18308 nt!IopfCallDriver+0x31
f42d7a5c 80570f9c 820d5c90 81b5e65c f42d7c04 nt!IovCallDriver+0xa0
f42d7b3c 8056386c 820d5ca8 00000000 81b5e5b8 nt!IopParseDevice+0xa58
f42d7bc4 80567c63 00000000 f42d7c04 00000040 nt!ObpLookupObjectName+0x56a
f42d7c18 80571477 00000000 00000000 57164c01 nt!ObOpenObjectByName+0xeb
f42d7c94 80571546 0012d554 c0100080 0012d4f4 nt!IopCreateFile+0x407
f42d7cf0 8057167c 0012d554 c0100080 0012d4f4 nt!IoCreateFile+0x8e
f42d7d30 804df06b 0012d554 c0100080 0012d4f4 nt!NtCreateFile+0x30
f42d7d30 7c90eb94 0012d554 c0100080 0012d4f4 nt!KiFastCallEntry+0xf8
0012d4b0 7c90d68e 7c810b2c 0012d554 c0100080 ntdll!KiFastSystemCallRet
0012d4b4 7c810b2c 0012d554 c0100080 0012d4f4 ntdll!NtCreateFile+0xc
0012d54c 7c801a4f 00000000 c0000000 00000000 kernel32!CreateFileW+0x1b6
0012d570 63d2207d 63d2909c c0000000 00000000 kernel32!CreateFileA+0x2b
0012d634 63d22178 00000000 00000001 00000094 VtuneApi!CloseMark+0x23c
0012d73c 63d25fc7 63d20000 00000001 00000000 VtuneApi!DllMain+0xb2
To verify this use verifier utility. This utility force paging of kernel code.
David_A_Intel1
Hi slavai:
To report potential bugs, please submit an issue at Intel Premier Support. This allows us to gather pertinent information to help in verifying and researching the problem. For example, you have not specified the OS and version.
