Analyzers
5339 Discussions
Using Vtune Amplifier GUI with X Forwarding
Shuwa_M_
I'm trying to use Vtune Amplifier GUI on a remote system with SSH X Forwarding. The GUI works fine except that it fails to find a valid license.
The remote system should have a valid license as I was able to invoke Vtune Amplifier CUI on the machine. Any tips would be appreciated.
PAVEL_G_Intel
Hi Shuwa,
I often works with VTune Amplifier via SSH X Forwarding and never seen the problem before. Could you check that *.lic is located in one of default paths:
/opt/intel/licenses
$HOME/intel/licenses
If you have license located in other directory you need to specify INTEL_LICENSE_FILE environment variable.
So the command line for start GUI will be looked as:
ssh -X user@host
INTEL_LICENSE_FILE=/path/to/license/dir  amplxe-gui &
