Analyzers
5328 Discussions
Using Windows Slim Reader Writer Locks gives false positives for data race?
Stefan_M_3
I have code which does the following:
ThreadA():
AcquireSRWLockExclusive(lock);
SharedVar = someVal;
ReleaseSRWLockExclusive(lock);
ThreadB()
AcquireSRWLockShared(lock);
var = SharedVar;
ReleaseSRWLockShared(lock);
When I run the Intel Inspector to Locate Deadlocks and Data Races it says that there is read/write data race in accessing the presimably locked SharedVar. Does the Intel Inspector properly work with slim reader / writer locks or should I just discard the issue as a false positive?
SergeyKostrov
Valued Contributor II
>>...When I run the Intel Inspector to Locate Deadlocks and Data Races it says that there is read/write data race... It looks right because both threads are not waiting until the shared resource is avalable. >>...should I just discard the issue as a false positive? Could you try the test case with TryAcquireSRWLockShared and TryAcquireSRWLockExclusive functions?
Bernard
Hi Stefan,
did you first initialize slim reader/writer lock with InitializeSRWLock() function?
SergeyKostrov
>>>>...When I run the Intel Inspector to Locate Deadlocks and Data Races it says that there is read/write data race... >> >>did you first initialize slim reader/writer lock with InitializeSRWLock() function? Intel Inspector XE would not detect the data race if something would be wrong with initialization the SRW lock. >>...should I just discard the issue as a false positive? Since ThreadA is a Writer thread ( changes value of the shared variable ) and ThreadB is a Reader thread ( reads value of the shared variable ) then a message about the data race could be considered as a warning. By design of SRW multiple threads ( readers! ) should be able to access some resource.
Stefan_M_3
Yes. I did initialize the lock. Also i have a test which will detect if a reader thread accesses not fully written data. The test has been running for a day with no issues.
I've also tried the sample from "Synchronization Primitives New To Windows Vista" (http://msdn.microsoft.com/en-us/magazine/cc163405.aspx). The Intel Inspector detects a race condition in that code too (in updateValue() and getValue()).
