Analyzers
5248 Discussions
VTStartSampling: Assertion `g_lsepAdapter != ((void *)0)' failed.
sihamina
I am sampling a code (based on pthread) using Vtune. I would like to print in a file the values of the events that correspond to each single iteration of a loop. I used VTStartSampling(&params) and VTStopSampling(1) as sepcified in the code written below but I got this error
: sampling.c:506: VTStartSampling: Assertion `g_lsepAdapter != ((void *)0)' failed.
I get the same error when I compile the code described below:
I compile it using : /opt/intel/cc64/bin/icc -I/opt/intel/vtune/rdc/analyzer/include/ -L/opt/intel/vtune/rdc/analyzer/bin -lVtuneApi vtune_code.cpp
and
I run it using: vtl activity -c sampling -app ./a.out run
I am using Vtune on a Linux x86_64 x86_64 x86_64 GNU/Linux.
Any suggestion!
#include "stdafx.h"
#include "VtuneApi.h"
int _tmain(int argc, _TCHAR* argv[])
U32 u32Return;
VTUNE_EVENT events[] = {
{ 10000, 0, 0, 0, "CPU_CLK_UNHALTED.CORE" }, // Sample After Value, Reserved, Reserved, Return Status, Event Name - my system is Intel Core 2 Duo
{ 10000, 0, 0, 0, "INST_RETIRED.ANY" }, //Use "vtlquery -c sampling" to know all supported events inyour system, in command prompt
U32 numEvents = sizeof(events) / sizeof(VTUNE_EVENT);
VTUNE_SAMPLING_PARAMS params = {
sizeof(VTUNE_SAMPLING_PARAMS),
sizeof(VTUNE_EVENT),
0, // sampling options
0, // reserved
0, // If 1, startsampling in pause mode
0, // maximum number of samples tobe collected.
1000, // number of samples per buffer
40,// the sampling interval in milliseconds
1, // "1" for event based sampling
numEvents,// number of events
events, // event list array
"results.tb5", // result file with or without full path
0, // reserved
0, // "1" - generate a count file "tb5Filename.txt"
"" // CPU mask
u32Return = VTStartSampling(&params); // start samplingsinceit is not in pause mode
if (u32Return) {
printf("Can't start sampling\\n");
exit(0);
for (int i=0; i<10000000L; i++); // do some work, data is captured
VTPauseSampling(); //pause data collection
for (int i=0; i<10000000L; i++); // do some work, data is NOT captured
VTResumeSampling(); // resume data collection
for (int i=0; i<10000000L; i++); // do some work, data is captured again
u32Return = VTStopSampling(1); // stop collecting data and write result into TB5 file, use VTuneAnalyzerto import it!
if (u32Return) {
printf("Can't stop sampling\\n");
exit(0);
return 0;
Peter_W_Intel
Please check -
1)Has vtune driver been loadedin system? Use "lsmod | grep vtune"
2)Can sampling collector work? Use "vtl query -lc"
3) If 1) and/or 2) is wrong, please check the reason
4) Use right events name in "VTUNE_EVENT events[]" - compare with outputof "vtl query -sampling"
5) Do NOT use vtl to launch your a.out - simply run a.out which can collect performance data, and.tb5 file should be generated.
Regards, Peter
sihamina
I checked all the points mentioned above. Everything looks Ok, however when I execute ./a.out I still get exactly the same error.
More suggestions!
Thanks again.
Peter_W_Intel
Thanks for raising this issue!
Actually I can reproduce this problem, butexample code ever worked on Windows* system.
Iprovide a temp solution -
1. Please don'tuse (remove) VTStartSampling() in your code,it also includes sampling configuration work. That means, vtl or vtlec will do all sampling configuration& start.
2. Also remove VTStopSampling() in your code, vtl or vtlec will do this.
So there are only VTResumeSampling() / VTPauseSampling() in your code.
I have verified - it works!!!
Bye the way, please use icc with "-g -O0". So symbol info will be generated, and code is not optimized. You can use like "vtl view -hf -mn a.out" to find hot functions, or view result on GUI directly
Regards, Peter
