Hi all,
I met a problem when try to proflie our xeon phi code with VTune 2015 (shown in the Figure below) :
Following the instruction, I find that all values of "Card number" in project properties dialog have been pre-initailized and that's a parameter we can't change manually.
Then I followed the steps as shown in the discussion below:
https://software.intel.com/en-us/forums/topic/536153
But an error appeared when restarting the mpss service:
[root@mdlslx111 ~]# service mpss restart
Restarting mpss (via systemctl): Job for mpss.service failed. See 'systemctl status mpss.service' and 'journalctl -xn' for details.
[FAILED]
[root@mdlslx111 ~]# systemctl status mpss.service -l
mpss.service - Intel(R) MPSS control service
Loaded: loaded (/etc/systemd/system/mpss.service; enabled)
Active: failed (Result: exit-code) since Fri 2015-04-03 11:46:35 CEST; 25s ago
Process: 211396 ExecStart=/etc/init.d/mpss start (code=exited, status=1/FAILURE)
Apr 03 11:46:35 mdlslx111 mpss[211396]: Starting Intel(R) MPSS: [FAILED]
Apr 03 11:46:35 mdlslx111 systemd[1]: mpss.service: control process exited, code=exited status=1
Apr 03 11:46:35 mdlslx111 systemd[1]: Failed to start Intel(R) MPSS control service.
Apr 03 11:46:35 mdlslx111 systemd[1]: Unit mpss.service entered failed state.
Any ideas? Thank you in advance.
Bests,
Yunsong
Could you please try VTune Amplifer XE 2015 Update 2? I remember we had such a bug for multi-card systems and it was fixed.
Thanks & Regards, Dmitry
I am facing the same license problem in Intel Vtune Amplifier XE 2015, 30 day trial period.
I surfed the previous questionnaire and found the following steps:
Open a command prompt on Windows and execute the following:
> cd c:\Program Files (x86)\Intel\VTune Amplifier XE 2015\
> amplxe-vars.bat
> set INTEL_LMD_DEBUG=1
> amplxe-cl > c:\temp\vtune_log.txt 2>&1
> set INTEL_LMD_DEBUG=0
After that, I am stuck as to what next??
Can someone please help me get it done.
Thank-You
To Trishla:
Not sure that the licensing issue is connected with Xeon Phi probelm in this thread - so it is worth to start a new one.
