Analyzers
VTune_Amplifier_XE_2016_update1 cannot profile GPU
merlion_m_
My former VTune is VTune_Amplifier_XE_2015_update1 and everything is fine.
However, after I installed the latest driver and VTune_Amplifier_XE_2016_update1, I cannot profile Platform Analysis/ CPU/GPU Concurrency.
I run the VTune in Administrator mode and every time I run it, it appears the screen in the attachment.
It writes "BUG: . Please contact the technical support."
What should I do?
Peter_W_Intel
Thank you of reporting this.
Did you work cpugpu-concurrency analysis on Windows or Linux? Run this in command line, when it occurred again, please send outputs to me, with result directory, then:
amplxe-feedback -create-bug-report <report archive>, also attach the report. Thank you.
It will be better if you can attach application, so we can reproduce this problem on my side. Do you use latest Intel MediaServerStudio?
Svetlana_K_Intel
Could you please attach the application you're profiling so that we could reproduce a problem on our side?
Do you happen to know if this is a driver regression or VTune regression? (or you just installed both at a time?)
