Analyzers
5156 Discussions
VTune: An Error occurred during drill-down
postaquestion
Completed sampling of a run through the application but when the file is opened and the sampling results are selected, an error box appears which says, "An Error occurred during drill-down. Cause of error cannot be determined".
Please advise.
We canattach the .VXP file that contains the saved run results if that helps.
David_A_Intel1
Hi:
Does this happen every time you collect sampling data or only for one specific application? That is, does it happen if you use vtunedemo?
In order to further investigate this potential defect, we need you to submit an issue to https://premier.intel.com. Intel Premier Support allows us to exchange information confidentially.
