Analyzers
5307 Discussions
VTune Hotspot/uarch exploration showing different Module-Function name on Bottom-up
Donghyeon
Hello I'm using VTune to profile some pytorch program.
I came across this issue while analyzing MKL's SGEMM.
The callstack(its module and function name) don't seem to match for Hotspot(HW event-based) and uArch exploration analysis.
Is there an underlying reason why? Thanks for the help
Gopika_Intel
Thank you for posting in Intel Communities. To reproduce the issue from our end, could you please share with us the following information:
1. Vtune version that you are using
2. A minimum sample reproducer code
Thank you in advance
Gopika
Gopika_Intel
We have not heard back from you. Is the query resolved? If not, please share with us the vtune version you are using and a minimum sample reproducer code to reproduce the issue from our end. If your issue is resolved, can we discontinue monitoring this thread?
Gopika
Gopika_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Gopika
