Analyzers
5341 Discussions
VTune Memory access and sampling driver
preeth
I was able to build the drivers by running ./build-driver -ni -pu as mentioned in Build and Install the Sampling Drivers for Linux* Targets (intel.com).
Got the message:
C compiler version: 7.5.0
Make version: 4.2.1
Kernel version: 5.3.18-57-default
Cleaning workspaces ...
Done
Building socperf driver ...
Done
Building sep driver ...
/../vtune/2024.1/sepdk/src/sys64.o: warning: objtool: .text+0x11: unreachable instruction
Done
Building pax driver ...
Done
Building vtsspp driver ...
make[1]: Entering directory '/../vtune/2024.1/sepdk/src/vtsspp'
make[1]: Leaving directory '/../vtune/2024.1/sepdk/src/vtsspp'
Done
Done building the drivers
When I try to install them using /insmod-sep -r I get,
the following ouput:
grep: /usr/lib/os-release: No such file or directory
PYTHON is set to python
Warning: the following driver(s) were not found loaded in the kernel: sep5.
Warning: no vtsspp driver was found loaded in the kernel.
Warning: no socwatch driver was found loaded in the kernel.
Warning: the following driver(s) were not found loaded in the kernel: socperf3.
The PAX service is not loaded anymore.
ERROR: sep5 driver "sep5-x32_64-5.3.18-57-defaultsmp.ko"
was not found in directory "." !
This means you may need to build sep5 driver from the provided
driver sources. Please see the driver README for instructions.
Note: Ensure that the driver is built for kernel version 5.3.18-57-default
I am trying to run memory access in VTune, Is there any other way other than installing sampling driver? If I have to install how do I go about it?
thanks
