Analyzers
5323 Discussions
VTune Profiling for User Image on ADB device
RatneshKum_T_Intel
 Hi
I am using VTune version : VTune 2018 Update 3
I  want to do profile for some apps on ADB device flashed by User Celadon Image on KBL-NUC.
I am doing VTune profile for target system : Android device (ADB) , Target Type: Attach to Process, Analysis Type: Basic Hotspot
I am getting an error:
Cannot attach to the target application due to an error returned by the 'run-as' utility. Suggestion: Make sure your Android image is installed correctly.
Also, when I switched to Target type: Profile System, and choose Analysis Type: Advanced Hotspot:
I am getting error:
This analysis type requires either an access to system-wide monitoring in the Linux perf subsystem or installation of the VTune Amplifier drivers (see the "Sampling Drivers" help topic for further details). Please set the /proc/sys/kernel/perf_event_paranoid value to 0 or less to continue without installing the drivers.
But when I do profile for Userdebug Image of Celadon flashing on KBL-NUC , and doing the above step on the same device. I do not see any error and successfully able to produce the result.
So can you please tell me, how to get  fixed these error while doing for User Image flashed on device.
Thanks in advance!!
Kirill_U_Intel
Hi
userdebug image could be rooted (adb root) and VTune have abilities for all collection types in this case.
user image could NOT be rootes and advanced hotspots are not available at all on such devices.
Basic hotspots needs to have 'run-as' correct working utility
could you share output from 'adb shell run-as NAME_OF_PROFILED_PACKAGE id'?
for example, adb shell run-as com.intel.vtune id
Thanks, Kirill
RatneshKum_T_Intel
Hi KIRILL,
Thanks for your reply.
Here I am sending you my details id after doing : adb shell run-as com.intel.vtune id
uid=10087(u0_a87) gid=10087(u0_a87) groups=10087(u0_a87),1004(input),1007(log),1011(adb),1015(sdcard_rw),1028(sdcard_r),3001(net_bt_admin),3002(net_bt),3003(inet),3006(net_bw_stats),3009(readproc),3011(uhid) context=u:r:untrusted_app_25:s0:c512,c768
Kirill_U_Intel
Could you share the run-as output for YOUR package? What is the name of profiled process?
RatneshKum_T_Intel
Hi Krill,
Here is the output after doing the : adb shell run-as com.jam.endo
run-as: package not debuggable: com.jam.endo
Thanks, Ratnesh
Kirill_U_Intel
I see.
Unfortunately we could not profile not debuggable packages without root permissions.
Is it possible to build com.jam.endo.apk  with debuug key?
androidmanifest.xml example
    <application
         android:debuggable="true">
    </application>
