Analyzers
5287 Discussions
[VTune] get latency histogram through command line
e_ds
I am using VTune to analyze different applications. I noticed that VTune generates a Latency Histogram in the Memory Access - Memory Usage - Summary tab, as reported here:
I would like to generate such latency values from command line to run additional analyses; however, I have found no way to that. I also looked at the SQLite DB that VTune creates in the project folder, but it seems that it contains just a portion of latency values within the "dd_memory_access" table.
Could you please help me with this issue?
Thank you!
yuzhang3_intel
Just confirmed that there is no way to generate the histogram from cli. I can only suggest “Copy to clipboard” from GUI functionality.
You’ll get such text representation:
Latency Histogram
Latency Loads
0 130039
7 70351099
8 10793237
9 2600780
12 1040312
13 520156
14 2080624
15 1170351
16 1300390
17 650195
18 130039
19 130039
20 390117
23 260078
24 130039
26 130039
29 130039
yuzhang3_intel
Do you mean you want to get a latency histogram as well when running other analysis types besides memory-access?
e_ds
Hello @yuzhang3_intel
Sorry for the misunderstanding. I would like to know if there is a way get the raw data of the latency histogram from command line.
My goal is to then perform my additional analyses on such data and make charts with different binning widths.
Thank you
yuzhang3_intel
Understood, let me check.
e_ds
@yuzhang3_intel
Ok, thank you for help! I'll wait for your answer then.
yuzhang3_intel
This is raw data extracted from the VTune macc data based on the timeline. I'm not sure if it is what you expected.
$ vtune -R timeline -r r015macc/ -r-k column-by=TotalLatency -r-k bin-count=100
e_ds
@yuzhang3_intel
Thank you for the reply. I have executed the command you suggested, but it does not exactly provide what I expected. With this command, I can see the total latency distributed over the timeline of my application according to the number of bins. For instance:
timeBin   Bin Start Time   Bin End Time   Total Latency:Self
0                               0.000              12.015         5,617,298,207
1                             12.015              24.030        1,027,101,981
However, in order to recreate the latency histogram chart from the Memory Access tab, I suppose I need to have the latency (in clock cycles) of each load instruction. Indeed, if I hover with the mouse the latency histogram, I can see how many loads share the same latency. This is somehow similar to what I found navigating the SQLite DB that VTune creates for a project, where each line of the "dd_memory_access" table contains data about the memory address, cache line, latency, and so on. Unfortunately, as mentioned in my first message, this table seems to contain just a subsample of the overall memory accesses.
Do you think it would be possible to extract the latency (in clock cycles) of each load instruction from the VTune command line?
Thank you for your help!
e_ds
@yuzhang3_intel
Sorry, another quick question related to your reply: how can I list the metrics that the "column-by" flag accepts?
I tried to look at the VTune documentation for that but I found a few metric examples only.
Thanks again!
yuzhang3_intel
Latency Histogram
Latency Loads
0 130039
7 70351099
8 10793237
9 2600780
12 1040312
13 520156
14 2080624
15 1170351
16 1300390
17 650195
18 130039
19 130039
20 390117
23 260078
24 130039
26 130039
29 130039
e_ds
@yuzhang3_intel
I see.
I hoped there was a way to generate the histogram data from the cli, but I think this solution is fine too.
