Analyzers
5285 Discussions
VTune give the following error => Assertion failed: gtpin_support:1656: (result == 1)
MichelBasili
I would like to perform an analysis of a programme using OpenCL. The standard analysis works and gives the desired results.
The analysis generates error Assertion failed: gtpin_support:1656: (result == 1) when I change the GPU software profiling mode setting from None to Instruction count. This is also the case when for snapshot performances I use "GPU Compute/Media Hotspots" and set the Source Analysis with Basic Blocks Latency.
Thank you for your time.
ThasneemV_Intel
Could you please share the following details:
1. Sample reproducer code.
2. VTune version.
3. Exact steps and the commands used.
4. OS, kernel and Processor details.
5. Self-checker logs.
The "vtune-self-checker.sh" script is available from <install-dir>/bin64 on the Windows or Linux system on which you installed VTune Profiler.
On running this script, it will create a log file and display the location of the log file. Kindly share that file with us so we can verify it from our side.
Thasneem Vazim
ThasneemV_Intel
We have not heard back from you. Could you please give us an update?
Thasneem Vazim
ThasneemV_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thasneem Vazim
