Analyzers
5063 Discussions
VTune project questions
postaquestion
Yesterday I downloaded VTune for a project I'm working on but I am having difficulty on getting it to run on the machine that I require it to run on. The installation works fine however when I attempt to run vtlec the eclipse browser run fine for a few moments before comming up with the following errors after closing.
app screen dump
JVM terminated. Exit code=1
/opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10/bin/java
-Dosgi.splashLocation=
/opt/intel/eclipsepackage/3.2.1_0/eclipse/plugins/com.intel.sdp.primary_2.0.3/splash.bmp
-Dosgi.sharedConfiguration.area=/opt/intel/vtune/bin/../shared/eclipse/configuration
-jar /opt/intel/eclipsepackage/3.2.1_0/eclipse/startup.jar
-os linux
-ws gtk
-arch x86
-launcher /opt/intel/eclipsepackage/3.2.1_0/eclipse/eclipse
-name Eclipse
-showsplash 600
-exitdata 7800c
-product com.intel.sdp.primary.product
-perspective com.intel.vtune.shell.tuningPerspective
-vm /opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10/bin/java
-vmargs
command line
172-16-7-11:/opt/intel/vtune/bin # ./vtlec
Parse Aborted: Encountered "=" at line 172, column 13.
Was expecting one of:
Ravi_V_Intel
I hope you have updated to a newer version of VTune Analyzer to check if this issue is resolved. If not, please create a Premier issue to provide more detailed information necessary to reproduce and resolve this issue.
