tdlr:
I'm not able to generate a VTune timeline report from the command line
Unknown error has happened in timeline data provider.
vtune: Error: 0x40000023 (User input error)
details:
See details below on how to replicate. Can you suggest how to fix this?
(Intel(R) VTune(TM) Profiler 2023.0.0 (build 624757) Command Line Tool )
Using the matrix example shipped with oneAPI (as in /opt/intel/oneapi/vtune/latest/samples/en/C++/matrix) I get the following:
STEP 1: build the application
cd ./matrix/src/
make
STEP2: profile hotspot
cd ../
vtune -collect hotspots ./matrix
STEP 3: generate a summary report [WORKS OK]
vtune -report summary -r r000hs/
STEP 4: generate a timeline report [FAILS]
vtune -report timeline -report-knob column-by="Thread" -r r000hs/
vtune: Using result path `/home/stephen/dv/VTUNE-HTML/matrix/r000hs'
vtune: Executing actions 0 %
vtune: Executing actions 0 % Finalizing results
vtune: Executing actions 50 % Finalizing results
vtune: Executing actions 50 % Generating a report
vtune: Executing actions 50 % Setting data model parameter
vtune: Executing actions 75 % Setting data model parameter
vtune: Executing actions 75 % Generating a report
vtune: Executing actions 100 % Generating a report
vtune: Executing actions 100 % done
one small typo in how to replicate the error. the matrix app should be built in the linux folder
Thanks you for posting in Intel Communities.
We are working on this internally. We will get back to you soon with an update. Meanwhile, could you also please share the OS and Hardware details.
Remya Premdas
Try : vtune -report timeline -report-knob=CPUTime -r r000hs/
or: vtune -report timeline -report-knob=CPUTime -report-knob group-by=Thread -r r000hs/
or: vtune -report timeline -report-knob=CPUTime -report-knob group-by=Thread -report-knob sort-column-by=PMUEventCount -r r000hs/
Note no space in "CPUTime"
We haven't received any update from you. Is your issue resolved?
Remya Premdas
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Remya Premdas
