Hi all, I have a problem using Vtune 8with files compiled(Intel compiler). from afortran 90sourcecode.
Vtune is not able to show the source code in making the analysis, is this function limited to C++?
John
Fortran is same as C or C++. Objects must be built with -g symbols, and source code available on the computer where VTune analyzer is running. If you use pre-processing, it may help to save the pre-processed source. The current VTune 8.0.2 version is able to show source code in some cases where previous versions were not.
Topic Options
