I have used Vtune 2015.4 to perform an 'Advanced Hotspots' analysis for a sequential code on a Haswell processor (CentOS release 6.6).
The line "CPU Frequency Ratio" ("The ratio between the actual and nominal Values of
CPU frequencies. Values above 1 indicate that the CPU operates in a turbo boost mode") indicates "1.130" (see attached file)
Vtune indicates that the node that is used is "r1i0n10" that "Frequency" (nominal ?) is 2.30Ghz.
As I understand, the CPU has reached an actual frequency of 2.3*1.130=2.5990Ghz ?
However, If I look at the node, I have for the frequency
[root@r1i0n10 ~]# cpupower frequency-info -o
minimum CPU frequency - maximum CPU frequency - governor
CPU 0 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 1 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 2 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 3 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 4 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 5 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 6 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 7 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 8 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 9 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 10 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 11 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 12 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 13 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 14 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 15 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 16 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 17 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 18 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 19 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 20 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 21 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 22 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
CPU 23 1200000 kHz ( 52 %) - 2301000 kHz (100 %) - ondemand
Since I did not ask for any variation of the CPU frequency when launching the code (and "maximum frequency" is 2.301Ghz), I don't understand why Vtune suggests that "the CPU operates in a turbo boost mode" with an actual frequency of 2.3*1.130=2.5990Ghz.
Could you help me understand this result please ?
All the best,
Anne-Sophie
