Analyzers
4998 Discussions
Vtune 9.0 crashes Vista
Alexei_Yakovlev
Hi all,
I've just installed Vtune analyzer 9.0 on my Windows Vista32 desktop and tried running some sampling tests. When I do one run only (select Min: One sampling run... in Sampling Configuration Wizard) everything works fine. If I do more than one sampling run (Medium or Max in the Sampling config Wizard) then the system crashes with a blue screen of death (saying something like error 0x00000101, can't see much more than that) after the first sampling run.
The computer:
Intel Core 2 Quad Q6600 running at 2.4GHz (not overclocked).
Motherboard: Asus P5B Deluxe
Graphics: Nvidia 7900GT
Memory: 4GB installed of which Windows can use about 3GB
OS: Windows Vista 32 bit.
Please let me know if you need more information.
TimP
A better way to go about this would be to submit an issue on premier.intel.com, including a pack-and-go file of your case.
Alexei_Yakovlev
tim18,
Thank you for the advice. I'll submit this case to the premier support although there is a small problem: I cannot use Pack'n'Go because it's an evaluation version that does not allow saving data.
Alexei
PHILLIP_C_Intel
Hi all,
The computer:
I don't believe Vista is supported for this tool. I'm having simular issues with Win7 and noticed that dl support is only for WinXP!
PHILLIP_C_Intel
Correction Vista32 is supported however, there seems to be an issue with With beta Win7 that I am dealing with. Time Based shows possilble file corruptions.
