Analyzers
5341 Discussions
Vtune cannot show the function name
hua0x522
We try to migrate a project from openmp and CUDA to dpc++ on remote Linux.
Firstly, we used a sparse matrix multiplication function to replace the old CUDA kernel. Then we profiled it by Vtune and we can see the function name.
However, we replace a piece of OpenMP code by parallel_for(dpc++), we found we cannot see the function name and there is only library name.
ShyamS_Intel
For dpc++ you can use any debug parameters while compiling -gline-tables-only and -fdebug-info-for-profiling , so it will show the information
Please refer the documentation if needed:
https://www.intel.com/content/www/us/en/develop/documentation/vtune-help/top/set-up-analysis-target/linux-targets/debug-info-for-linux-binaries.html
(Or) If program is taking negligible amount of time to run, also cause this kind of issue.
Shyam Sundar
ShyamS_Intel
Could you please provide any updates.
Shyam Sundar
ShyamS_Intel
I assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Shyam Sundar
