Hello.
There is a problem with Vtune + ifort 2022 + vs2019.
Can you please tell me how to make it so that instead of references like func@0x140051b90
to output function names from source Fortran program?
If I disable /O0 optimization, then function names are displayed correctly.
However, if I use /O3, I get addresses instead of names.
The compilation is carried out with the parameters
/nologo /debug:full /O3 /Qaxcoffeelake /Qxcoffeelake /reentrancy:none /arch:AVX /Qoffload:none /tune:coffeelake /Qopenmp-offload- /Qopenmp-stubs interfaces /Qopt-report:5 /fpe:0 /module: "x64\Release\\" /object: "x64\Release\\" /Fd "x64\Release\vc160. pdb" /traceback /libs:static /threads /Qmkl:sequential /c
Linking with parameters
/OUT: "x64\Release\neumann_1d_msu.exe" /INCREMENTAL:NO /NOLOGO /MANIFEST /MANIFESTFILE: "x64\Release\neumann_1d_msu.exe.intermediate.manifest" /MANIFESTUAC: "level='asInvoker' uiAccess='false'" /DEBUG /PDB: "d:\Disk\Parallel\fortran\2d_Extra_Laguerre_ALL\2d_Extra_Laguerre8\x64\Release\neumann_1d_msu. pdb" /MAP /MAPINFO:EXPORTS /SUBSYSTEM:CONSOLE /STACK:2000000000,2000000000 /IMPLIB: "d:\Disk\Parallel\fortran\2d_Extra_Laguerre_ALL\2d_Extra_Laguerre8\x64\Release\neumann_1d_msu.lib"
For linux system I have no problem with this.
Thank you.
I'm going to close this thread for support as a duplicate of https://community.intel.com/t5/Intel-Fortran-Compiler/Vtune-problems-Ifort-vs2019/m-p/1350470. VTune is not related to the actual problem, it is simply a way to see the problem.
VTune reads information about function names from .pdb files. Are there any warning messages about symbol file of this module in VTune finalization output/log? Can you see function names for this module under VS debugger?
Can your share a reproducer: small VTune result + executable module (this program or any other "hello world" app with such issue) + its .pdb file?
Thank you for providing the reproducer. The attached .exe file doesn't have information about its .pdb in the IMAGE_DEBUG_TYPE_CODEVIEW debug directory. As a result, VTune doesn't try to find the .pdb. Help is needed from the Compiler team to understand why there is no reference to .pdb.
We are working on this internally, will get back to you with the solution. Thank you for your patience.
Raeesa
