Analyzers
Vtune on i9-13900K
wmeier
Vtune said that the processor was not recognized as Genuine Intel, or was not supported.
When will Vtune be updated for the i9-13900K?
funny
I also have this issue,
Can anyone provide more details of the next release which can support the 13th desktop CPU?
JaideepK_Intel
We are working on this internally, please share the details below.
1. OS details (eg: Windows10, linux: ubuntu20.04,centos8, RHEL7.9,etc..).
2. Please let us know if you are facing this issue while using latest version of Vtune(2022.4)
For windows:
1. Run command prompt as administrator
2. To set the environment variables run the below command:
<Vtune_installation_directory\2022.2.0\vtune-vars.bat>
example: C:\Program Files (x86)\Intel\oneAPI\vtune\2022.2.0\vtune-vars.bat
3. To run vtune-self-checker run the below command:
<Vtune_installation_directory\2022.2.0\bin64\vtune-self-checker.bat>
example: C:\Program Files (x86)\Intel\oneAPI\vtune\2022.3.0\bin64\vtune-self-checker.bat
For linux:(run as root/super user)
sh <oneapi_install_directory>/vtune/latest/bin64/vtune-self-checker.sh
(eg: sh /opt/intel/oneapi/vtune/latest/bin64/vtune-self-checker.sh)
Please attach the self-checker log (latest version of Vtune) to proceed further.
Jaideep
funny
OS:        Windows 11 22H2
Vtune:   2022.4
CPU:     13900K
C:\Program Files (x86)\Intel\oneAPI\vtune\2022.4.0\bin64>vtune-self-checker.bat
Intel(R) VTune(TM) Profiler Self Check Utility
Copyright (C) 2009 Intel Corporation. All rights reserved.
Build Number: 624343
HW event-based analysis (counting mode)
Example of analysis types: Performance Snapshot
Collection: Fail
vtune: Error: This analysis type is not applicable to the system because VTune Profiler cannot recognize the processor. If this is a new Intel processor, please check for an updated version of VTune Profiler. If this is an unreleased Intel processor, please contact Online Service Center for an NDA product package.
vtune: Error: This analysis type is not applicable to the current machine microarchitecture.
Instrumentation based analysis check
Example of analysis types: Hotspots and Threading with user-mode sampling
Collection: Ok
Finalization: Ok...
Report: Ok
HW event-based analysis check
Example of analysis types: Hotspots with HW event-based sampling, HPC Performance Characterization, etc.
Collection: Fail
Example of analysis types: Microarchitecture Exploration
Collection: Fail
HW event-based analysis with uncore events
Example of analysis types: Memory Access
Collection: Fail
HW event-based analysis with stacks
Example of analysis types: Hotspots with HW event-based sampling and call stacks
Collection: Fail
HW event-based analysis with context switches
Example of analysis types: Threading with HW event-based sampling
Collection: Fail
Checking DPC++ application as prerequisite for GPU analyses: Fail
Unable to run DPC++ application on GPU connected to this system. If you are using an Intel GPU and want to verify profiling support for DPC++ applications, check these requirements:
* Install Intel(R) GPU driver.
* Install Intel(R) Level Zero GPU runtime.
* Install Intel(R) oneAPI DPC++ Runtime and set the environment.
The check observed a product failure on your system.
Review errors in the output above to fix a problem or contact Intel technical support.
The system is ready for the following analyses:
* Hotspots and Threading with user-mode sampling
The following analyses have failed on the system:
* Performance Snapshot
* Hotspots with HW event-based sampling, HPC Performance Characterization, etc.
* Microarchitecture Exploration
* Memory Access
* Hotspots with HW event-based sampling and call stacks
* Threading with HW event-based sampling
* GPU Compute/Media Hotspots (characterization mode)
* GPU Compute/Media Hotspots (source analysis mode)
machinemily
I have the same issue on my i9 13900K with Z690 chipset.
aptinit
I am also having the same issue.
OS:        Windows 11 22H2
Vtune:   2022.4
CPU:     13900K
MB:       MSI Z690 Crabon
Self-test output:
Collection: Fail
Collection: Ok
Finalization: Ok...
Report: Ok
Collection: Fail
Collection: Fail
Collection: Fail
Collection: Fail
Collection: Fail
Exception in thread Thread-24:prerequisite for GPU analyses...
Traceback (most recent call last):
File "build\build_release_win32-x86_64_icl_19.0.228_mstools_15.0\python.sitelib\sitelib\threading.py", line 980, in _bootstrap_inner
File "build\build_release_win32-x86_64_icl_19.0.228_mstools_15.0\python.sitelib\sitelib\threading.py", line 917, in run
File "build\build_release_win32-x86_64_icl_19.0.228_mstools_15.0\python.sitelib\sitelib\subprocess.py", line 1479, in _readerthread
File "build\build_release_win32-x86_64_icl_19.0.228_mstools_15.0\python.sitelib\sitelib\codecs.py", line 322, in decode
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xd0 in position 0: invalid continuation byte
* Memory Access
Log file in attachment.
aptinit
Still having the same issue for the latest version.
OS:        Windows 11 22H2
Vtune:   2022.4.1
CPU:     13900K
MB:       MSI Z690 Crabon
Self-test output:
Build Number: 624516
Collection: Fail
Collection: Ok
Finalization: Ok...
Report: Ok
Collection: Fail
Collection: Fail
Collection: Fail
Collection: Fail
Collection: Fail
* Memory Access
JaideepK_Intel
We were able to reproduce your issue from our end, and we informed the concerned team. We will get back to you with an update.
Jaideep
JaideepK_Intel
Hi All,
The above issue is resolved in the latest version of Vtune.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
