Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Vtune stuck at Finalizing results
Hi, when I try to use Vtune for I/O Analysis, it gets stuck displaying:
 Finalizing Results 25%: Loading 'sep13b8.20201011T131203.770758.tb7' file
 I am using it in Visual Studio 2017, running Windows 10. The version is 2020 Update 2. The program I am running uses Intel SGX in debugging mode.
I do not know why this happens, the other analysis types do not get stuck.
Highlighted
Thanks for posting in Intel forums.
Could you try your I/O analysis in vtune standalone version and let us know?
Highlighted
Yes, I tried it. It gets stuck at the same step using the standalone version too.
Highlighted
Hi.
Could you just import tb7 from the result dir? Is it still hang?
Kirill
Highlighted
Hi, could you please tell me how exactly I should do that? These are the commands that I tried,  but it does not find tb7:
C:\Program Files (x86)\IntelSWTools\VTune Profiler 2020\bin64>vtune -import sep3a40.20201013T191635.419476.tb7 -result-dir r029io
C:\Program Files (x86)\IntelSWTools\VTune Profiler 2020\bin64>vtune -import tb7 -result-dir r029io
Highlighted
you should set full path to result_directory with hang data.
something like
vtune -import VTUNE_PROJECT_DIR/rXXXio/data.0/sep3a40.20201013T191635.419476.tb7
Highlighted
Yes, now it works, thank you. The data are displayed in the command line, is there any way I could open them in the GUI?
Highlighted
To import files from vtune-gui, select button and select import result option. When import result window opens,you have to give the path to the file and select import option to import the file. Refer the below documentation for more information.
https://software.intel.com/content/www/us/en/develop/documentation/vtune-help/top/analyze-performanc...
Highlighted
Is your issue resolved? Do you have any update?
Highlighted
We are assuming that the solution provided helped and would no longer be monitoring this issue.Please raise a new thread if you have any further issues.
