Analyzers
5135 Discussions
What does the Inspector Caution mean?
missing__zlw
I saw this in the TBB tutorial:
The instrumentation support for Intel Parallel Inspector becomes live after the first
initialization of the task library (3.1). If the library components are used before this
initialization occurs, Intel Parallel Inspector may falsely report race conditions that
are not really races.
I don't understand it. Does it mean when I run my program (using tbb) multiple times in the inspector, false reace conditions will be reported?
Rob5
New Contributor II
I interpret the caution as, make sure the TBB task scheduler is initialized before using the library components in your source. If TBB is not implemented properly, then unexpected results may occur when your application is executed. Section 3.1 of the Intel Threading Building Blocks tutorial provides additional information about how the task scheduler is or can be initialized. So, make sure the TBB implantation is working from that perspective before running analysis.
For reference, this question also appears to be posted on the TBB forum.
- Rob
Mark_D_Intel
Inspector will not find races across processes (or across multiple runs of a single program).
What this means is that some parts of TBB can be used without initializing the task scheduler library. For instance, a program could use the concurrent_hash_map without initializing the task scheduler library.
However, in order for Inspector to understand all of the TBB synchronizations, it needs some special synchronization API's turned on. What this caution means is that these aren't turned on until the task scheduler library is initialized.
Consequently, there may be cases where one needs to add an explicit task scheduler initialization to a program in order for it to be properly analyzed by Inspector.
Peter_W_Intel
I recommend toadd a MACRO TBB_USE_THREADING_TOOLS when compiling code which calls TBB libraries.
