One of the requirements of Intel software tools and compilers is an Intel processor. I am using AMD and WinXP.
Vtune has limited capabilities on an AMD processor (time based sampling should work, no Event Based counters enabled). The compilers do well, but evidently not all of their capabilities are useful on AMD. This is what trials are for, to see whether it's worth while for you.
just small addition:
call graph works perfectly. Counter Monitor is also fine.
I'm trying use the VTune, but I have had trouble with TBS32.dll. It could be happening due my processor to be a AMD?
When I try to sample a simple C++ program (matrix multiply) ocour the message "HRESULT
produce 0x80004005 in VTSamplingWiz.cpp line 439".
How can I fix it?
How can I fix it?
