Analyzers
5338 Discussions
amplxe error while using Vtune on a multiThreaded application
Ayman_Supcom
Hello I am trying to use Vtune to profile my application withe the command:
[amplxe-cl -collect hotspots -result-dir vtune_outputs/formula_100  application.exe]
and i faced  the errors :
amplxe: Error: Assertion failed: tpss_completion:126: (queue_buffer_data != 0) : . Please contact the technical support.
amplxe: Error: Assertion failed: tpss_stack_data_type:131: (stack->data) : . Please contact the technical support.
Note that i am applying multi-threading using threading building blocks Library and thanks to some Logs I found out that the fail is happening when the program is executing the multi threaded function.
Also I am not facing the error when I am not trying to lunch Vtune.
Thank You.
JaideepK_Intel
Can you please share the requested details below:
1. What is the version of Intel® Vtune?
2. Please share your OS (Windows 10,11 or Linux distribution) and processor details?
3. Please share the exact steps that you followed and a sample reproducer(sample application that is similar to the application you are trying to analyze)?
We tried threading building blocks library using the OneAPI sample(tbb-async-sycl sample code which was implemented using C++ and SYCL language for CPU and GPU) and it is running without any issues. Attaching the screenshot for reference.
Jaideep
Ayman_Supcom
Hi @JaideepK_Intel  Thank you for your response .
I am using  CentOS Linux version 7, my machine is Intel(R) Xeon(R) Gold 6256 CPU @ 3.60GHz and VTune version 2018, I built the application in debug mode . I tried to reproduce the error while using VTune and I had the attached error ,that doesn't occur while trying only to launch the application without VTune. I added an environment variable also To specify whether the execution of threads is sequential or parallel , and I noticed that the problem occurs only when I am using parallelization .
 can you please give me any suggestion about any possible common mistake i could have done , or any modification on the command so that i can avoid the error .
Thank You .
Ayman.
JaideepK_Intel
As you mentioned, you are using Vtune 2018, can you use the updated version(Vtune 2022). Please note that CentOS 7 is not supported in the latest Vtune 2022 version. Please consider changing the OS and try with the latest Vtune version.
Work around: Try using docker (docker pull intel/oneapi-basekit) and profile application with remote ssh.
System requirements link:
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/vtune-profiler-system-requirements.html
Jaideep
JaideepK_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
