hello,
I installed vtune in CLI mode; when i run it with an application, i get the following error:
amplxe: Warning: Skipped generation of report `summary': no valid license can be found (Could not find the Intel product license file. Suggestion: Please check if: (1) the environment variable INTEL_LICENSE_FILE points to the correct Intel license file directory and (2) this directory contains a valid license (.lic) file for this Intel product. Internal error code: `-76'.).
How can i get the license for the evaluation? I didnt see such a link in download page.
Thanks in advance.
cinar.
I've emailed your eval license to the address you provided. You can also get your license by logging into https://registrationcenter.intel.com and clicking the serial number under the Serial Numbers tab. You can put the license file in /opt/intel/licenses and it should automatically pick it up.
Jennifer
