Analyzers
find-leaks on already running analysis
manik_s_
When I try to run the following command on already running analysis , I get an error that is :
COMMAND = inspxe-cl -command find-leaks -result-dir r000mi3/
ERROR = Warning : Cannot communicate with the process.
Can you tell me how to get memory leaks from the running analysis without stopping it ?
manik_s_
I forgot to add that I am able to STOP the running analysis with this command.
Mark_D_Intel
What version of Inspector are you using?
Is this Windows or Linux?
How did you start the original Inspector process?
manik_s_
@mark-dewing
I am using intel inspector XE 2013 on Linux.
inspxe-cl -collect mi2 -search-dir all:rp=<path-to-sources+symbols> -executable-of-interest=<my-executable-name> -verbose -- <my-application-startup-script>
Mark_D_Intel
Do you have the right directory specified in command?  The collection command is for 'mi2', and the directory in the find-leaks command (r000mi3) would have been started with 'mi3'.
(Since you said you could stop the collection with '-command stop', this may just be an inconsistency in the posted text.)
If that is correct, could you look at <result directory>/inspxe-runmc.log.  It should have a more detailed description about the command-error in there.  (Alternately, you could send the whole result directory to me to look at).
manik_s_
The text 'mi2' is a type error in my last comment. I hve given the correct directory in the command when i did my analysis. I m sure abt that. Even when i try to find-leaks during memory analysis in GUI i get this error of 'Warning : Cannot communicate with the process.'
Mondal__Deepankar
I am having the same issue. This is on windows. I get the following error in inspxe-runmc.log
<msg id="2" tool="runtool">
  <type>command-error</type>
  <description>unable to open lock file for sending command to collector</description>
</msg>
