Analyzers
how to inspect source from a profile run of a "release" compilation?
PKM
Hello
Any hints to how you link a profile run of a "release" compilation to its source code? I have tried enabling debug information for the release compiler settings, but it doesn't seem to do the trick ... It works fine when I do a run for a "debug" compilation ...
Any help is greatly appreciated ...
(Parallel Studio XE 2013 on Windows)
David_A_Intel1
Hi Casper:
You have to make sure the linker settings are enabling debug info, as well.  Basically, assuming Visual Studio*, see the Linker -> Debugging tab, and enable Generate Debug Info.  Generate Program Database File should also be configured (should do it automatically when you enable Debug Info).
PKM
PKM
