Analyzers
5285 Discussions
how to print sampling results
gastineau
Hye,
I want to print or save to a file (pdf or text, ...) the window of the "sampling results" in the vtune window on linux OS (Itanium version). I want to print Bar chart or the table.
And how to print source file code with precent information ?
Do you will provide a version of intel thread checker and profiler for linux (with eclipse gui) ?
Mickael,
aokunev
Hi Mickael,
It is posible to save table content to CSV file and then use it as a source for data manipulation. Please use File->Export->"Results to Text" menu in Eclipse. You will be asked a file name. The same steps can be used for source file. Current view will be saved in CSV format.
I do not know anything threading checker/profiler with eclipse gui.
regards, Andrei
