Does __itt_resume/__itt_pause work for "Performance Snapshot"?
It works for other analysis such as "Hotspots", "Threading" and etc.
The version of my VTune is 2022.2.0.
Thank you.
Ethan Kim
itt_resume() and itt_pause() works fine with performance snapshot. It might not be visible in the results but there will be some difference in the elapsed time. We tried using itt_resume() and itt_pause() functions in a sample code and did performance snapshot analysis and we could observe some difference in the elapsed time.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Shyam Sundar
Thank you for your reply.
I'm still not sure that __itt_resume works for 'Performance Snapshot'.
Below is a sample source code that I made just for this.
I compiled it as 'VS2019 Console Application x64 Release' with all other configuration being default.
#include <iostream>
#include <thread>
#include "C:/Program Files (x86)/Intel/oneAPI/vtune/latest/include/ittnotify.h"
#pragma comment(lib, "C:/Program Files (x86)/Intel/oneAPI/vtune/latest/lib64/libittnotify.lib")
int main()
double dSum = 0.0;
__itt_resume();
std::this_thread::sleep_for(std::chrono::seconds(5));
for (int i = 0; i < INT_MAX; i++)
dSum += 1.0;
__itt_pause();
std::cout << dSum;
If I start 'Hotspots' by clicking 'Start Paused', 'Collection is paused' changes to 'Collecting Hotspots data'.
If I start 'Performance Snapshot' by clicking 'Start Paused', 'Collection is paused' does not change to 'Collecting ... data'.
Can you take a look at this?
Thank you again.
Ethan Kim
We used the same code which you provided and it worked fine while performance snapshot.
Shyam Sundar
Just for sure, did you start analysis with "Start Paused"?
Very awkward situation happens to me.
If I run VTune as administrator, it seems that _itt_resume does NOT work. Please see below.
If I run VTune 'NOT' as administrator, __itt_resume does work. Please see below.
I will try with a whole new PC.
My current PC has an antivirus program and Symatec Data Loss Prevention solution installed. Can these disturb VTune?
Ethan Kim
We are working on this internally.
Will let you know once we get an update.
Shyam Sundar
