Analyzers
5231 Discussions
no information in results
david_z_
I've created a test program(just creating 10 threads and increasing a global integer variable 1 per second in each thread). And I use this command to attach vtune to get some hotspots in test:
amplxe-cl -collect hotspots -target-pid 7765 -duration 30
(test's pid is 7765)
after this, I got the results with nothing like this:
amplxe: Collection started. To stop the collection, either press CTRL-C or enter from another console window: amplxe-cl -r /root/test/r025hs -command stop.
amplxe: Collection detached.
amplxe: Using result path `/root/test/r025hs'
amplxe: Executing actions 50 % Generating a report
Collection and Platform Info
Parameter                 r025hs
Application Command Line
Operating System          3.0.13-0.27-default SUSE Linux Enterprise Server 11 (x86_64)
VERSION = 11
PATCHLEVEL = 2
Computer Name             linux-6dsc
Result Size               1488862
Collection start time     09:46:56 09/10/2014 UTC
Collection stop time      09:47:26 09/10/2014 UTC
CPU
Parameter          r025hs
Name               Intel(R) Core(TM) i7 Processor
Frequency          2908808012
Logical CPU Count  1
Summary
Elapsed Time:  0.000
CPU Time:
amplxe: Executing actions 100 % done
1. Elapsed Time: 0.000
2. no call stack information in GUI
3.no .th files in result dir
Anyone please help me on this. Thank you in advance:)
Peter_W_Intel
I can reproduce this problem, based on your description for test case.
The reason was that "var++" take extreme small CPU time, then sleep(1) doesn't has data collected. I changed example with "var++" in loop, which costed more CPU time, then with sleep (1). After doing hotspots collection, the result was expected. Please see my example attached.
# g++ -g threads_10.cpp -o threads_10 -lpthread
# ./threads_10 &
[1] 28407
# amplxe-cl -collect hotspots -target-pid 28407 -duration 30
# amplxe-cl -report hotspots
amplxe: Using result path `/home/peter/problem_report/r002hs'
Function  Module      CPU Time:Self  CPU Time:Idle:Self  CPU Time:Poor:Self  CPU Time:Ok:Self  CPU Time:Ideal:Self  CPU Time:Over:Self  Overhead Time:Self  Spin Time:Self
funcA     threads_10          5.640               0.480               3.101             1.570                0.489                   0                   0               0
Peter_W_Intel
# ./threads_10 &
[1] 28407
david_z_
Yes! Now I have everything in result! Thank you Peter Wang (Intel).
