Analyzers
5273 Discussions
pax driver failed to load (intel vtune profiler 2020, update 2, ubuntu 20.04)
jolars
I am getting the following error message when trying to install intel vtune profiler 2020, update 2:
Warning:  the following driver(s) were not found loaded in the kernel:  sep5.
Checking for PMU arbitration service (PAX) ... not detected.
Attempting to start PAX service ...
Executing: insmod ./pax/pax-x32_64-5.4.0-42-genericsmp.ko
insmod: ERROR: could not insert module ./pax/pax-x32_64-5.4.0-42-genericsmp.ko: Operation not permitted
Error:  pax driver failed to load!
You may need to build pax driver for your kernel.
Please see the pax driver README for instructions.
Error: failed to start or connect to required PAX service
Everything else in the installation seems to have worked properly. If I try to repair the installation or install the drivers separately, I run into the same issue.
I am on a local install (not a virtual machine) of ubuntu 20.04, kernel 5.4.0-42-generic (which seems to match the driver).
I have checked the prerequisites in the PAX readme file and everything seems to be set up properly.
ChithraJ_Intel
Hi Johan,
Thanks for your update.
Pax driver is actually part of SEP. VTune drivers are unsigned and a secure boot requires cryptographically signed drivers to be used. As of now this is not supported by vtune. As a fall back , you can make use of perf if SEP is not available.
Since your issue is resolved by turning off secure boot, shall we discontinue monitoring this thread?
Chithra
Kirill_U_Intel
Hi.
Could you share dmesg info after calling insmod-sep script?
Thanks, Kirill
Kirill_U_Intel
I mean dmesg log like this one
kuhanov@localhost:~/kuhanov# dmesg
[26125.796955] PAX: PMU arbitration service v1.0.2 has been started.
[26127.129954] socperf3_0: SocPerf Driver loading...
[26127.129956] socperf3_0: SocPerf Driver about to register chrdev...
[26127.129958] socperf3_0: SocPerf Driver: result of alloc_chrdev_region is 0
[26127.129959] socperf3_0: SocPerf Driver: major number is 234
[26127.129963] socperf3_0: SocPerf Driver: detected 96 CPUs in lwpmudrv_Load
[26127.129964] socperf3_0: SocPerf Driver: creating device socperf3!c...
[26127.130069] socperf3_0: PMU check enabled! F6.M55.S7 index=-1
[26127.130070] socperf3_0: No MMIO list information detected!
[26127.130072] socperf3_0: SocPerf Driver v3.0.0 has been loaded.
[26128.146089] sep5_20: Driver loading...
[26128.147756] sep5_20: [load] [UTILITY_Driver_Log_Init@1011]: Initialized driver log using contiguous physical memory.
[26128.147763] sep5_20: [load] [lwpmu_Load@6557]: Major number is 511
[26128.147774] sep5_20: [load] [lwpmu_Load@6564]: Detected 96 total CPUs and 96 active CPUs.
[26128.196196] sep5_20: [load] [lwpmu_Load@6859]: PMU collection driver v5.20.6 Beta has been loaded.
[26128.196201] sep5_20: [load] [lwpmu_Load@6869]: NMI will be used for handling PMU interrupts.
[26128.196209] sep5_20: [load] [PMU_LIST_Initialize@654]: PMU check enabled! F6.M55.S7 index=7 drv_type=PUBLIC
[26129.263512] vtsspp: Driver version 1.8.229-611328
[26129.266501] vtsspp: Kernel version 5.4.0-31-generic
[26129.266506] vtsspp: Detected 96 CPUs
[26129.266509] vtsspp: CPU family: 0x06, model: 0x55, stepping: 07, HT: yes
[26129.266510] vtsspp: CPU freq: 2095077KHz, timer freq: 1000000KHz
[26129.266518] vtsspp: PMU: fixed counters: 3, general counters: 4
[26129.269084] vtsspp: KPTI is enabled
[26129.269085] vtsspp: KASLR is detected
[26129.269087] vtsspp: Driver has been loaded
[26129.291553] -----------------------------------------
[26129.291555] OK: LOADED SoC Watch Driver
jolars
Thanks; I get
[10705.376420] Lockdown: insmod: unsigned module loading is restricted; see man kernel_lockdown.7
jolars
Could this be related to UEFI secure boot (which I have enabled)?
Kirill_U_Intel
I suppose yes.
could you try this one?
To get the module loading, disable kernel lockdown via sys-rq:
# echo 1 > /proc/sys/kernel/sysrq
# echo x > /proc/sysrq-trigger
from
https://unix.stackexchange.com/questions/543576/modprobe-fails-with-operation-not-permitted
jolars
I just did, actually, but to no avail.
Another post (https://forums.centos.org/viewtopic.php?t=47224) recommended checking if CONFIG_MODULE_SIG_FORCE is enabled at compile-time, or if enforcemodulesig=1 is enabled at boot, but they are not.
cat /boot/config-`uname -r` | grep CONFIG_MODULE_SIG_FORCE
# CONFIG_MODULE_SIG_FORCE is not set
Is there any particular reason for why the driver is not signed? I am not thrilled about the prospect of disabling secure boot.
Kirill_U_Intel
I think it is not possible on general system.
we must have signing keys.
you could sign them if you build kernel yourself.
Kirill
ChithraJ_Intel
Has the solution provided by Kirill worked for you. Please let us know if the issue still persists.
Chithra
Kirill_U_Intel
Also VTune allows to run driverless hardware collections based on the perf. Probably you could skip building/installing vtune drivers at all and get the useful profile.
Kirill
jolars
Well, turning off secure boot does solve the problem, even if it's not really solving my problem.
The driverless option works too, but I prefer to use the drivers.
ChithraJ_Intel
Hi Johan,
Chithra
ChithraJ_Intel
Hi Johan,
Thanks for the confirmation. We would discontinue monitoring this issue.Please raise a new thread if you have further issues.
Chithra
