Hallo,
I try to build it at /opt/intel/oneapi/vtune/2025.8/sepdk/src
using: sudo ./build-driver
but have the the following errors:
C compiler to use: [ /bin/gcc ] /usr/bin/x86_64-linux-gnu-gcc-13
C compiler version: 13.3.0
Make command to use: [ /bin/make ]
Make version: 4.3
Kernel source directory: [ /lib/modules/6.14.0-37-generic/build ]
Kernel version: 6.14.0-37-generic
Cleaning workspaces ...
Done
Building sep driver ...
sys64.o: warning: objtool: .text+0x35: unreachable instruction
sys64.o: warning: objtool: .text+0x36: unreachable instruction
/bin/sh: 1: pahole: not found
make[4]: *** [/usr/src/linux-headers-6.14.0-37-generic/scripts/Makefile.modfinal:57: sep5.ko] Error 127
make[4]: *** Deleting file 'sep5.ko'
make[3]: *** [/usr/src/linux-headers-6.14.0-37-generic/Makefile:1928: modules] Error 2
make[2]: *** [/usr/src/linux-headers-6.14.0-37-generic/Makefile:251: __sub-make] Error 2
Could you pls help me by solving this problem? Thanks, Binh
Can you try installing dwarves package and try the build again?
sudo apt update
sudo apt install dwarves
thanks you for your info.
Unfortunately, I also have errors after successfully installing dwarves like:
sys64.o: error: objtool: .text+0xf9: unreachable instruction
make[4]: *** [/usr/src/linux-headers-6.17.0-14-generic/scripts/Makefile.build:430: sys64.o] Error 1
make[4]: *** Deleting file 'sys64.o'
make[4]: *** Waiting for unfinished jobs....
make[3]: *** [/usr/src/linux-headers-6.17.0-14-generic/Makefile:2016: .] Error 2
make[2]: *** [/usr/src/linux-headers-6.17.0-14-generic/Makefile:248: __sub-make] Error 2
make[1]: *** [Makefile:248: __sub-make] Error 2
Thanks again. Binh
There might have been 2 issues with your build.
and one of them was resolved by installing dwarvs.
to resolve the another issue, add --make-args="OBJECT_FILES_NON_STANDARD_sys64.o:=y" in the build command like below
./build-driver -ni --make-args="OBJECT_FILES_NON_STANDARD_sys64.o:=y"
