Analyzers
5273 Discussions
problem with vtune amplifier
satya_b_
Dear all,
             I whave written bunch of FORTRAN 90 codes and compiled with ifort. I have made Makefile as follows.
OBJECTS := co2_ads.o sub_change_pot.o sub_total_pot.o sub_del_pot.o sub_ins_pot.o sub_translationmove.o sub_rotmove.o sub_deletionmove.o sub_insertionmove.o sub_chempot.o sub_trans_sample.o sub_hmatrix.o global_mod.o constants_mod.o cavity_var.o ewald_mod.o sub_cavity.o sub_gasmolcavity.o sub_total_kspace.o sub_total_bonded.o sub_del_kspace.o sub_del_kspace1.o sub_kspace_ins.o
co2_ads.x: $(OBJECTS)
ifort -o c.x -O $(OBJECTS)
%.o: %.f90
ifort -c $<
clean:
rm -f *.o *.mod
Then I executed ./c.x. However, I want to see which part of code among these codes are taking more time. For that I used Vtune profiler as with following command
amplxe-cl -collect hotspots /tmp/r001/ -- ./c.x
 I got an error as follows:
amplxe: Error: Failed to start profiling because the scope of ptrace system call application is limited. To enable profiling, please set /proc/sys/kernel/yama/ptrace_scope to 0. See the documentation for instructions on enabling it permanently.
amplxe: Using result path `/home/satya/main-code/fmof-1-cal/r000hs'
amplxe: Executing actions 24 % Processing profile metrics and debug information
amplxe: Warning: Error 0x40000026 (Database interface error) -- Cannot run data transformation `Compute CPU Usage'.
amplxe: Executing actions 50 % Generating a report
Collection and Platform Info
Parameter r000hs
Application Command Line ../ewaldcavity-biased/c.x
Operating System 3.5.0-37-generic DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=12.10
DISTRIB_CODENAME=quantal
DISTRIB_DESCRIPTION="Ubuntu 12.10"
Computer Name darbari
Result Size 1027794
CPU
Parameter r000hs
Name Intel(R) Core(TM) Processor 2xxx Series
Logical CPU Count 8
Summary
Elapsed Time: 0.000
amplxe: Executing actions 100 % done
Can you please explain me, what could be the error I made.
Thank you.
Kirill_R_Intel
VTune Amplifier XE can't run Hotspots analysis if ptrace is set to non-zero.  As the error message says, you need to set it to 0 in /proc/sys/kernel/yama/ptrace_scope file.
