Analyzers
"file corrupted" error
kshitizmalik
Hello!
I was trying to use the QPA wizard on an executable file, I get a "file corrupted or unrecognizable format" error, and QPA wizard doesn't even load the file.
I am on a Windows XP machine, the exe was a C program compiled with gcc for windows. It runs *fine* from the command line.
I saw another post from someone else about this, but his problem was that the directory path to his exe contained some chinese characters.
Help!!
-k
Paul_P_Intel1
Hi...
Have you submitted your request for support to the VTune support team? If you registered your VTune product, you should have already set up a support account with them.
This forum is mainly for discussions on ways to use VTune to optimize code and diagnose performance issues. The support team is available to answer questions about why VTune may act unexpectedly or does not work.
Message Edited by paparent on 04-21-2004 04:42 AM
