Analyzers
5296 Discussions
sepdrv.sys causes bluescreen
Marcin_Piaskiewicz
For some time now I get bluescreen with crash inside this driver. Sometimes a reset is sufficient. I run a Vista x86 Home Premium SP2 and Intel VTune Build:719.
I noticed a post with similar crash on forums. Is there a fix for this?
I noticed that .NET applications stopped running (error 80004005), once I uninstalled VTune they run correctly (no reboot after uninstall was needed). I remeber that sometimes I received similar error 80004005 when one of .NET applications was scheduled to run at boot (auto start), however this occurred only sometimes.
Kind Regards,
Marcin Piaskiewicz
Peter_W_Intel
Current VTune Performance Analyzer version is v9.1, Update 8 - build #406.
If you already have registered the product, please download it from https://registrationcenter.intel.com/RegCenter/Download.aspx?productid=1104
Please help to review if the problem has gone or NOT. If you can reproduce the problem, please submit a ticket to https://premier.intel.com with necessary test case and steps.
If .NET application should run at boot time, sampling data collection can't do .NET sampling profiling, just do regular sampling profiling.
Regards, Peter
