Analyzers
tuning ASM code?
dfati
Is tool good and usable for tuning ASM code?
Kirill_R_Intel
Yes, you can tune ASM code with Intel VTune Amplifier XE. On screenshot below you can see C++ and ASM source view.
Kirill_R_Intel
dfati
Thanks. To clarify, if I only has .ASM source (no .C, .CPP, etc..) I could still open it up and see something simlar with each instruction timed?
Kirill_R_Intel
Yes, you should be able to see ASM sources.
TimP
Event counts will not necessarily be allocated to instructions as you might expect; they may be attributed to subsequent instructions which consume the result of the instruction of interest.
