Analyzers
tutorial fails to build
Sundaram_R_Intel
Apologies if I am in the wrong forum. I am a first time user.
I am trying to run tachyon_conf using Visual Studio 10. I see only .sln file under VC8, unlike other tutorials on parallelization that had three .sln files for VS5, VS8 and VS10. When I select it, the VS does some kind of conversion. When I do step 3 on page 3 (build) of the evaluation guide, I get one failure.
Is this a known problem? Any guidance?
Ramu
Peter_W_Intel
Hi Ramu,
If you are working on Windows 7, you have to extract to tachyon_insp_xe.zip to your folder, e.g. c:\temp. Note that if you try to covert VS2008.sln to VS2010 .sln under c:\program files (x86)\intel\Inspector XE 2011, it willcause converting failure (UAC issue).
Regards, Peter
