Analyzers
vTune won't install?
marton
I'm having problems installing vTune on my XPSP2 main box. I go through the usual dialogs (license, install type, etc) then the progress bar starts, goes about halfway, and then I get a message that the setup could not be completed.
Any ideas?
-Marton
David_A_Intel1
What version of the VTune analyzer are you trying to install? Have you downloaded version 7.2. There is a known issue with version 7.1 on Microsoft Windows* XP SP2 (http://www.intel.com/support/performancetools/vtune/v71/sb/cs-014754-prd1391.htm).
marton
Thanks, the new download (7.2) installs just fine. It wasn't available when I purchased VTune and I wasn't notified of the new version either.
-Marton
David_A_Intel1
I'm glad it's working now.
If you have registered your purchase and created your support account on Intel Premier Support, you will receive an automated email notifying you of new releases available for download. Perhaps the notification was sent prior to your registering?
The other thing to do is periodically (i.e., monthly) check the "What's New?" section on Intel Premier Support. When new releases are made available, we typically post somethingin the"What's New?" section that stays there for a month or more.
